Civil 3D Forum
Modelling two orifice outlets from pond
2 REPLIES 2
ralstogj
281 Views, 2 Replies
Hi
Is it possible to model 2 orifice outlets from your pond typical we have a manhole rise weir overflow and then say two pipe outlet orifice at different  heights to control flows for the 2 and 10 year events.
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
2 REPLIES 2
Charlie.Ogden
in reply to: ralstogj
Yes, but you're probably getting an error connecting them both to the outfall - you'll want to join the two orifices at a junction first.
Charlie Ogden, PE
Product Manager
ralstogj
Charlie
Thank you thought that maybe the case. Just use to doing pond outlets in HEC-HMS.
Regards
[airey]
Justin Ralston
Senior Engineer - Manager Queenstown
AIREY CONSULTANTS LTD
P.O.Box 2069, Wakatipu, Queenstown, 9349? Level 2, Von House, Remarkables Park
Ph +64 3 442 3101 ? Fax +64 3 442 3102 ? Mob +64 274 566 660
Email justinr@aireys.co.nz ? Web www.aireys.co.nz
The information contained in this email is privileged and confidential and intended for the addressee only. If you are not the intended recipient, you are asked to respect that confidentiality and not disclose, copy or make use of its contents. AIREY CONSULTANTS LIMITED ACCEPTS NO RESPONSIBILITY FOR CHANGES MADE TO THIS EMAIL OR ANY ATTACHMENTS AFTER TRANSMISSION FROM AIREY CONSULTANTS LTD. If received in error you are asked to destroy the email and contact the sender immediately.
P Please consider the environment before printing this email.
Regards
Justin Ralston
Rail Community
