Is anyone getting odd results when importing pipe networks from StormCad v.8 via LandXML? I'm using the stand-alone version for C3D 2008. It always puts the outlet gound elevation at zero. Sometimes it puts the pipe centerline elevations at the rim elevations of the structures. Sometimes it reverses the pipes on their own centerline, causing really weird results.
I have opened every XMLfile with XML Notepad and checked that the data that came out of StormCad is correct. But something in the translation back to C3D 2008 goes haywire. I love C3D, if only I could be more confident of importing pipe data.
Also, as long as I'm whining, anyone come up with a good way to get HGLs into your profiles?
Thanks in advance,
Jerry.
