AutoCAD Civil 3D - Stormwater
Active Contributor
Lyonstp
Message 1 of 4 (243 Views)
IDF table error
243 Views, 3 Replies
07-20-2012 07:59 AM
For some reason, in the IDF rainfall curve window, when i enter my rainfall data into the IDF table tab i receive the following "Data Error": "No Solution: values may be non-uniform or unrealistic. values should increase with return peroid"
The problem is i have tried 3 sets of data. one that i know has worked in the past and i am still getting the same error. the rainfall data is from a government website so the numbers should be good.
has anyone experienced this problem before?
Employee
Matt.Anderson
Message 2 of 4 (241 Views)
Re: IDF table error
07-20-2012 08:05 AM in reply to: Lyonstp
Which program and what set of numbers are you using?
Matthew Anderson, PE
Product Manager
Active Contributor
Lyonstp
Message 3 of 4 (237 Views)
Re: IDF table error
07-20-2012 08:32 AM in reply to: Matt.Anderson
sorry, i forgot to mention that. I am using Hydraflow Hydrographs extension for Civil 3D. The data i am using i got off of the NOAA website, they are  "PDS-based point precipitation frequency estimates" i'm using the 1,2,5,10,25,50 & 100 year storm events with 5,10,15,30, 60 minute durations.
Employee
Matt.Anderson
Message 4 of 4 (239 Views)
Re: IDF table error
07-20-2012 09:51 AM in reply to: Lyonstp
Be sure to use the "Precipitation intensity" Data Type from the NOAA website rather than the "Precipitation depth".
Sounds like you are using the depth values.
Product Manager
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
