Civil 3D Forum
Hydrographs: Variable Tailwater Elevation
4 REPLIES 4
jack0001
1153 Views, 4 Replies
Hydraflow Hydragraphs Extension
1. Is there a way to model a pond with a tailwter that varies over time?
2. Is there a way to export a reservoir's resulting elevation vs. time data?
4 REPLIES 4
jalneal
in reply to: jack0001
Not to my knowledge there is.  The only type of variable tailwater analysis that Hydraflow Hydrographs has is the interconnected ponds, routines.  Otherwise, you can just put in a static tailwater in the outlet parameters.
Rather than trying to update a structure to mimic a variable tailwater in hdyraflow, I'd recommend modeling anything with a variable tailwater condition in SSA.  With SSA you can create a channel section, run a flow through it, set the Tc, etc. and it will essentially build a rating curve.  It also can serve to determine if you increase the peak at this downstream point.  Main thing you have to do if you use SSA with hydrodynamic routing is just make sure you understand and read up on the parameters, and check all your link time series to see that they look correct and don't show oscillations in them. There are several threads regarding parameters for hydrodynamic modeling.
Alan Neal, P.E.
Autodesk Infrastructure Suite Premium 2012/2013
Windows 7, x64
Xeon E31225 w/ Quadro 600
rdbrennan48
Also, in SSA you can set up a time series, hydrograph, with time vs. elevation to an outlet. I have used this to correlate a seperate detention model with my pipe network.
jack0001
in reply to: rdbrennan48
And SSA stands for...?
rdbrennan48
Storm and Sanitary Analysis
Rail Community
