• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Member
    Accepted Solution
    Hydraflow Express Culverts - Negative Invert Elevation
    205 Views, 2 Replies
    10-27-2012 04:03 PM
    I am analysing a culvert in a tidal zone which has an outlet invert level below the normal tidal range. The invert level of the culvert outler is -0.520m, however Hydraflow Express Culverts will not allow a negative invert elevation to be entered.
    Does anyone know a way around this?.
    Regards
    Lar Hughes
    Please use plain text.
    Employee
    Matt.Anderson
    Re: Hydraflow Express Culverts - Negative Invert Elevation
    10-29-2012 06:36 AM in reply to: iepms
    Lars -
    The workflow would be to move the datum up such that 0 m is now 10m and all of the elevations are postive.
    It would be advisable to use Autodesk Storm and Sanitary Analysis for tidal culverts.  It does not have the negative elevation limitation and can adequately solve tidal culverts with flap gates.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Autodesk, Inc.
    Member
    10-29-2012 04:51 PM in reply to: Matt.Anderson
    Matt
    Thank you very much for your reply. I will try and model this culvert in SSA. Do you know if SSA will output similar results for a culvert as Hydraflow Express - i.e. HGL's, Hw Elevation, Hw/D, results schematic and wheter the culvert flow regime is inlet or outlet control.
    Lar
