• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    How to get SSA to let me set my own Boundary Condition elevation
    157 Views, 2 Replies
    04-23-2012 03:05 PM
    The proposed storm drain system connects into an existing system in my project design.  I am modeling the proposed, and using an outfall at the connection to the existing system (I would prefer not to model the existing system as it is large and cumbersome).  I would like my boundary condition to reflect a predetermined elevation, but I am having trouble adjusting the starting water surface elevation.  I have tried using a fixed elevation or a time series function, but the boundary condition won’t adjust above the unimpeded normal depth.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Please use plain text.
    Valued Mentor
    Re: How to get SSA to let me set my own Boundary Condition elevation
    06-21-2012 07:12 PM in reply to: tcorey
    i am pretty sure i have experienced similar problem (sorry, not in front of computer, but will look up a recently done model and re-confirm tomorrow with some relevant screenshots). can anyone shed some light into this, as to why SSA is not honoring a specified tailwater boundary condition? SSA version 2011.
    Civil 3D 2013 SP1, Win 7-64 bit
    12GB RAM
    06-25-2012 08:13 PM in reply to: engineer4life1979
    Have you tried setting the Link Routing Method in the Project Options dialog to Hydrodynamic? I think setting the routing method to “Hydrodynamic” will honor the boundary condition of defined WSEL.
    Thank you,
    Debajit
