AutoCAD Civil 3D - Stormwater
New Member
kininak
Message 1 of 2 (420 Views)
Gutter Width - Hydraflow Storm Sewers Extension Program
420 Views, 1 Replies
12-07-2011 11:51 AM
I have a question about what the gutter width definition is compared to the grate width.  Are they the same thing?  The gutter width I am referring to here can be found in the 'Add/Edit Dialog' window under "Gutter Details".
If there is a catch basin (grate of 2 ft. by 2 ft.) along a highway on the shoulder that is 10 ft. wide, what is considered to be the "gutter width"?  Is it 2 ft. or 10 ft.?  Say the 10 ft. shoulder has a slope of 3% and the roadway has a slope of 2%, what should the gutter width be?
Also, what should be entered as Sx (Road Cross Slope) if the crown of the road splits off at the edge where the shoulder and road meets?  Should the 2% Road slope be considered in this case even if it does not pitch towards the catch basin?
Valued Mentor
Message 2 of 2 (404 Views)
Re: Gutter Width - Hydraflow Storm Sewers Extension Program
12-09-2011 06:13 AM in reply to: kininak
in your case, i would use the gutter width as the width of the inlet grate (2 ft), and use the 3% as the gutter and road cross slope (treating the rest of the shoulder as the travel lane). if your gutter spread is more than the width of the shoulder (past the high point), then i would make it a double inlet. hope this helps.
Civil 3D 2013 SP1, Win 7-64 bit
12GB RAM
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
