AutoCAD Civil 3D - Stormwater
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Error 517 in SSA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm getting the following error:
ERROR 517 : Error in reading TR-20 project data.
but when I compare my raingage input to the one in samples it appers to be correct. Is there someplace else I need to be checking? The file is attached if that will help.
Re: Error 517 in SSA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Problem is related to your Dimensionless Unit Hydrograph. Values in Dimensionless Unit Hydrograph should be in between 0(zero) to 1. Change the values in Dimensionless Unit Hydrograph it will solve your problem
Amit Garg
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your response. However, I didn't input the unit hydrograph, I checked the SCS Type II and changed the 4" intensity to a 4.08in. per the local requirements. If I go back to the default or even to a different county I still get the same error. If I deleate the raingage and recreate it using the defaults I get the same error. Were you able to get it to run?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please find the attached model which is ruuning. I just removed the Dimensionless Unit Hydrograph and chaged the WSEL for one storage node
