AutoCAD Civil 3D - Stormwater
Active Member
Message 1 of 2 (328 Views)
EGL and HGL Jump Error in Autodesk SSA
328 Views, 1 Replies
08-29-2012 07:20 AM
I'm new to SSA and have been testing it for the past day.  I have read through the user's guide, which states that junction losses are not used in the software.  Instead, minor losses are applied as an equivalent friction loss over the length of each pipe.  Given this calculation methodology, there should never be any "jumps" in the EGL at standard junctions since no loss is occuring there.  Each profile simulation that I run, however, invariably shows jumps in the EGL at various junctions.  Some junctions even exhibit an increase in EGL, which makes no logical sense.  Also, the HGL is droping at each junction unexpectedly too.  Could someone offer an explanation for this?  I've attached an example where the flow is constant, and all minor losses are 0.  Yet, the jumps occur.
Active Member
Message 2 of 2 (298 Views)
Re: EGL and HGL Jump Error in Autodesk SSA
09-12-2012 09:34 AM in reply to: kahligsm
Has anyone had a chance to examine this?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
