AutoCAD Civil 3D - Stormwater
New Member
lpeavey
Message 1 of 2 (646 Views)
Creating IDF curve based on County storm data
646 Views, 1 Replies
06-27-2012 11:00 AM
I've created an idf curve based the Santa Clara County data.  They use a specific equation to calculate the intensity (Santa Clara Valley Water District's Return Period-Duration-Specific (TDS) Regional Equation).  I have calculated the intensities, see attached "Rainfall Intensity Spreadsheet".  When I input these intensities for the 5, 15, 30, and 60 minute durations in order to create an idf curve, the intensity values on the curve Hydraflow produces are less than what I input (see "IDF curve").  I've checked my input into the table and it is correct.  The intensity values are a little lower than those required by the County.
For example, the 2 yr - 5 min required is 1.7, but Hydraflow gives 1.58.  It's not off by much but it's different when it should be the same.
What am I doing wrong?
Thanks!
Lana
Employee
Matt.Anderson
Message 2 of 2 (631 Views)
Re: Creating IDF curve based on County storm data
06-28-2012 05:49 AM in reply to: lpeavey
Lana -
The Hydraflow tools provide a quick method to calculate the standard BDE coefficients by entering three durations.
Review http://civil3dpedia.com/2009/10/16/engineering-101-idf-curves/ to manually calculate the correct values.
You may want to review the regression values of the Santa Clara rainfall to see if it fits better with a polynomial set of equations.
Matthew Anderson, PE
Product Manager
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
