I have imported a pipe network from Civil 3D 2014 into Storm and Sanitary Analysis 2014. And I see that for inlets, you have to convert the junction to an inlet manually. Is there a way to select several inlets at once and convert them to inlets, or do I have to right-click on each one individually?
AutoCAD Civil 3D 2014
AutoCAD Storm and Sanitary Analysis 2014
Windows 7 Professional SP1 (64-bit)
Intel Xeon CPU E31240 @ 3.30 GHz with 16.0 GB RAM
Group Edit feature in Storm and Sanitary Analysis only allows you to edit the properties of the elements.
Before you export the pipe network from Civil 3D to Storm and Sanitary Analysis, you may want to make sure that you set the Part Matchup setting for the Civil 3D Party Type to Storm Sewers Part Type accordingly so that all your structures are imported into SSA as you intended to. Similarly you may need to set the part matchup settings for your Import.
