AutoCAD Civil 3D - Stormwater
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Catchment areas are worthless
- Highlight
- Email to a Friend
Why in world would I want a feature that I can not edit.
Only way to edit is to explode (twice) to get it back to polylines and then convert back to Catchment area.
Get what happens when you explode catchment areas - NOT ALWAYS - but they generally cause errors. = CRASH
Would love to talk to the person that came up with this idea.
TROY
Civil3D 2012
Windows 7 Pro, 64 bit
Intel Xeon E31225 @ 3.40Ghz
16 GB RAM
Re: Catchment areas are worthless
- Highlight
- Email to a Friend
Catchments are a function of the surface to which you created it. If you wish to edit, the Catchment area command creates a polyline using the same calculations the catchment object uses. Edit, and then convert to an object.
If you wish to explode an object, type explode first, then select the catchment.
Matthew Anderson, PE
Business Consultant
Global Services
Autodesk, Inc.
- Highlight
- Email to a Friend
how do you edit a catchment that was created from object?
- Highlight
- Email to a Friend
You edit the object prior to converting it to a catchment.
Business Consultant
Global Services
Autodesk, Inc.
- Highlight
- Email to a Friend
But after you create the catchment, in the "real engineering world" things happen, I need to move a structure and then the catchment needs to be updated. Therefore you either delete and start over or explode twice and get back to a polyline and then recreate the catchment. As I said before, exploding catchment areas will causes drawing errors from time to time.
Catchment areas should be able to be edited just like feature lines
Civil3D 2012
16 GB RAM
- Highlight
- Email to a Friend
Matt:
How do you edit a catchment made from an object after the catchment is created?
Are you stating this is not an option?
I've never had a project without revisions...
- Highlight
- Email to a Friend
You can not edit. That is my whole problem with catchments.
Civil3D 2012
16 GB RAM
