AutoCAD Civil 3D - Stormwater
wfberry
Message 11 of 21 (679 Views)
Re: Cannot print from SSA 2013
08-07-2012 11:39 AM in reply to: bigblittlerent
Back in late JUNE, I was informed that it was a BUG in 2013.
Bill
Distinguished Contributor
Message 12 of 21 (677 Views)
08-07-2012 11:41 AM in reply to: wfberry
Tx for the update.
Active Contributor
rdbrennan48
Message 13 of 21 (669 Views)
08-09-2012 11:54 AM in reply to: wfberry
Any work on if they are fixing it and when. It's kinda annoying!
wfberry
Message 14 of 21 (664 Views)
08-09-2012 12:56 PM in reply to: rdbrennan48
Just remember one thing.  As long as Autodesk is on the NASDAQ or any other board, the employees are mandated to not divulge anything that may influence stock prices.
Just remember, no news until it is a fact.
Bill
Active Member
Message 15 of 21 (630 Views)
09-05-2012 07:47 AM in reply to: mrich012
I contacted Autodesk in July 2012 and got this answer from their Support Specialist:
I would like to inform you that the issue you reported is a known issue with our development team. It has been documented and sent to our development team for investigation.
As a workaround for the print command, you may want to first generate the Custom Report/PDF report or copy the ASCII reports to Textpad/Notepad or generate the spreadsheet report to print it out from the PDF or Spreadsheet. Alternatively, you may save the model and open it in SSA 2011 or 2012 and print it from there.
While this is all good and well if you want to print reports, it doesn't help with printing the Plan View layout.  I had to download the 2011 version of SSA and so far have had good luck with printing.  The problem with 2011 SSA, however, is having to dumb down all our 2013 AutoCAD files that we want to insert as backgrounds.
Valued Contributor
Message 16 of 21 (591 Views)
10-17-2012 08:24 AM in reply to: wfberry
Has anyone heard about a fix for this issue?
Member
Message 17 of 21 (574 Views)
10-22-2012 06:04 AM in reply to: wfberry
Yes, we are also having issues with this... Has anyone found a solution to the problem?
Valued Contributor
Message 18 of 21 (568 Views)
10-22-2012 06:20 AM in reply to: wfberry
I submitted a Support Request to Autodesk and received this note back:
You are correct, the issue with print command from SSA 2013 is a known issue with our development team. It has been documented and sent to our development team for investigation. I am afraid I do not have any ETA for the fix at the moment.
So I guess we'll have to wait for a hotfix.
Member
Message 19 of 21 (566 Views)
10-22-2012 06:22 AM in reply to: spilon
Thanks for the update...
New Member
Message 20 of 21 (486 Views)
12-26-2012 10:53 AM in reply to: mrich012
I get an error when trying to print from SSA 2013 like everyone else.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
