AutoCAD Civil 3D - Stormwater
Member
Message 1 of 4 (176 Views)
Average depth attained = 0
176 Views, 3 Replies
12-26-2012 01:56 PM
I just learned to use SSA. After running the model, the average depth attained is only 0.02-0.07 ft in the Node Depth Summary. What is the possible reason? Many thanks.
Active Contributor
Message 2 of 4 (146 Views)
Re: Average depth attained = 0
01-03-2013 12:44 PM in reply to: NoWandering
Sorry.  Can't answer the question without more information or a file.
Employee
Matt.Anderson
Message 3 of 4 (127 Views)
01-17-2013 01:35 PM in reply to: NoWandering
The longer you run the simulation when the depth at your node is zero, your average will decrease.
Matthew Anderson, PE
Product Manager
ICP
Member
Message 4 of 4 (100 Views)
02-05-2013 07:33 AM in reply to: Matt.Anderson
Matt, you are right.
I figured it out before you replied this. Originally I used 30 days. After changed to 1 day, the average depth is reasonable.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
