• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D - Stormwater
    Member
    Average depth attained = 0
    146 Views, 3 Replies
    12-26-2012 01:56 PM
    I just learned to use SSA. After running the model, the average depth attained is only 0.02-0.07 ft in the Node Depth Summary. What is the possible reason? Many thanks.
    Please use plain text.
    Active Contributor
    Re: Average depth attained = 0
    01-03-2013 12:44 PM in reply to: NoWandering
    Sorry.  Can't answer the question without more information or a file.
    Employee
    Matt.Anderson
    01-17-2013 01:35 PM in reply to: NoWandering
    The longer you run the simulation when the depth at your node is zero, your average will decrease.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Member
    02-05-2013 07:33 AM in reply to: Matt.Anderson
    Matt, you are right.
    I figured it out before you replied this. Originally I used 30 days. After changed to 1 day, the average depth is reasonable.
