In the “pipe networks” ribbon I click “modify” -> “apply rules” then it prompts me to select an upslope structure and subsequent downslope pipe or structure until I reach the end of my network. It says rules correctly applied to # of stuctures or pipes, however I am not prompted to select WHICH rule I would like to apply. After it says the rules have been correctly applied it still isn’t applying them to all pipes (see screenshot, the two highlighted pipes are not following the rule I would like.)
Solved by jmayo-EE. Go to Solution.
Go to the Network Properties dialog box and make sure the partlist with the correct rule set is selected.
John Mayo
