AutoCAD Civil 3D - Stormwater
AAristi
Message 1 of 7 (243 Views)
Additional "Connected Pipe" item to list of properties
243 Views, 6 Replies
10-06-2011 10:36 AM
I'm looking for a way to add another "Connected Pipe" item to list of properties of the Structure Label Text Component Editor?
I would like to add something like:  "Connected Pipe Status" or "Connected Pipe Condition".  It would have to be a String field which can be easily edted within the drawing.
I know how to edit the XML file to add custom field to the pipes, but those are not recognized by the Structure Label properties.
Any help will be greatly appreciated.
Employee
tomyao
Message 2 of 7 (220 Views)
Re: Additional "Connected Pipe" item to list of properties
11-01-2011 03:01 AM in reply to: AAristi
Hi, I successfully edit the XML file to add custom properties to the structures, and get the items from labels.
Could you attach your modified XML file and let's see what the problem is?
AAristi
Message 3 of 7 (204 Views)
11-09-2011 06:24 AM in reply to: tomyao
Here are the XML files for the Structure and Pipe
Employee
tomyao
Message 4 of 7 (191 Views)
11-16-2011 12:52 AM in reply to: AAristi
Sorry, I haven't found any custom property in your attached XML file.
I'd suggest you to modify the XML file in following path: C:\ProgramData\Autodesk\C3D 2012\enu\Pipes Catalog\Aecc Shared Content\AeccPartParamCfg.xml, instead of the XML file of individual part type.
For example, I added a property called 'Abc' for stucture domain in the following XML file.
Hope it meet your requirement.
AAristi
Message 5 of 7 (189 Views)
11-16-2011 08:45 AM in reply to: tomyao
Thank you for your help.
  Are these the XML files you were talking about?
  As I mentioned before, I was able to add custom information to the pipe (Additional Custom Information field), but it is not recognized by the connected Structure.  I need to be able to have that information show up in the Connected Pipe Data, or at least on the Structure labels.
Employee
tomyao
Message 6 of 7 (179 Views)
11-17-2011 10:30 PM in reply to: AAristi
We can customize Pipe properties for Pipe label or Stucture properties for structure label. But currently there's no way to show the connnected pipe's customized properties in stucture label. The connnected pipe's properties listed in stucture label style are hard coded.
AAristi
Message 7 of 7 (174 Views)
11-18-2011 06:49 AM in reply to: tomyao
That's what I was affraid of.
  I wish there was a way for an extra "Description" field to be used.  The current "Description" field on the Pipes is the only editable field that the Structures read from the pipe information.  If Autodesk created a way for the users to add additional "Description" fields it would help a lot.
  Thank you for all your help.  I'll keep looking for a work-around.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
