Hi All,
Anyone know why there is no 150mm pipe as standard in the SFA Drainage Stormwater parts list? The smallest pipe is a 250mm...
Is this just a UK related problem?
The shipped catolgue is not that great to add extra sizes you have to type partbuilder at the command line.
go into the pipe type you want and add the size in the values table from memory. This will update you catolgue on your local machine. What you should do is put the catolgues in a shared location and point everyones civil3d to it with set pipe network catologue setting.
