Here's what my setup is:
I have a Base.dwg where I xref-Attach a Proposed.dwg file into. I changed the Color=gray and Plot Style=Existing of the Proposed xref in the Base. Visretain=1.
I now create a Sheet.dwg and xref Base into it (and Proposed comes along too). The settings for Proposed are not what I have set in the Base file, they are what's in the original Proposed file.
Can I get these settings to come through? I cannot go into the original Proposed file and change settings.
C3D2012 W7
Solved by BrianHailey. Go to Solution.
Brian,
I thought of this after my post. Your example and video is exactly what I need. I need to remember the additional "check off" in the Restore options. I am going to export the Layer State so that it's easy for others to find as well.
Thanks!
Brian,
What software did you use to create that video. that is a great teaching tool for this website.
