does anyone know where i can find the xml editor in Civil3D 2010, i am trying to edit the file to make pipes draw in automatically 'BySlope' as per Chris' post but cannot figure out how to edit the xml code.
thanks, Jon
Solved by AlmasSuljevic. Go to Solution.
Hi Jon,
Without knowing what Chris mentioned I can tell you that you may use Notepad to edit XML files. My preferred tool for editing is called XML Notepad which you can download from here. http://www.microsoft.com/downloads/en/details.aspx?familyid=72d6aa49-787d-4118-ba5f-4f30fe913628&dis...
I am sure there are other tools as well. If you're referring to LandXML reporting tools you may find it:
C:\Program Files (x86)\Autodesk\LandXML Reporting 8. Just run EXE file. This tool may give you some editing options such as precision, units, etc.
Sorry if I confused you.
He's refering to this magnificent post http://blog.civil3dreminders.com/2008/11/pipe-rules-making-pipe-byslope.html and that's my prefered XML editor as well. In a pinch I'll use Notepad.
jrasd you may want to consider using .NET in 2010 for some speed improvements, although the rule in question wouldn't take up much time.
Christopher
