would be possible stepped spillways with corridor ?
It might be possible as long as the cross section is uniform. Looking at the second picture it seems that the individual steps are curved, which would not be possible in a corridor.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Assuming that all the steps are in fact uniform/straight (not curved as the second image seems to show), then your biggest hurdle will be providing a profile along the centerline of the spillway. Once you've done that, it would simply be a matter of making an assembly that creates the spillway.
Have a look at this for the stepped profile part.
Don Ireland
Engineering Design Technician
Hello. This link isn't working anymore. Do you have another soluction? I'm traying to do the stepped spillway. Any tip?
I suggest you make a custom subassembly that uses 4 elevation targets: 2 for the sidewalls, 1 for the bottom inner channel, and 1 for the Datum level.
Then make layout profiles for all of them, and assign them as targets in your corridor.
Remember that C3D does not admit vertical falls in profile, so you must give a point at a very small distance in each step fall.
Regards.
