Civil 3D Forum
would be possible stepped spillways with corridor ?
7 REPLIES 7
Message 1 of 8
alexandre_ssp
808 Views, 7 Replies
7 REPLIES 7
Message 2 of 8
sboon
in reply to: alexandre_ssp
It might be possible as long as the cross section is uniform.  Looking at the second picture it seems that the individual steps are curved, which would not be possible in a corridor.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 3 of 8
Do you have an example? Tutorial
Thank you for your attention
Message 4 of 8
doni49
Assuming that all the steps are in fact uniform/straight (not curved as the second image seems to show), then your biggest hurdle will be providing a profile along the centerline of the spillway.  Once you've done that, it would simply be a matter of making an assembly that creates the spillway.
Have a look at this for the stepped profile part.
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/infrastructure-design-suite/cr...
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 5 of 8
lucas.campos86AL4
in reply to: doni49
Hello. This link isn't working anymore. Do you have another soluction? I'm traying to do the stepped spillway. Any tip?
Message 6 of 8
Hi @lucas.campos86AL4
I suggest you make a custom subassembly that uses 4 elevation targets: 2 for the sidewalls, 1 for the bottom inner channel, and 1 for the Datum level.
Then make layout profiles for all of them, and assign them as targets in your corridor.
Remember that C3D does not admit vertical falls in profile, so you must give a point at a very small distance in each step fall.
Regards.
Message 7 of 8
MUKASWE
in reply to: RonaldBrañez
Hi @lucas.campos86AL4  can you share a screen shot of the subassembly if possible
Message 8 of 8
MUKASWE
Hi @lucas.campos86AL4  can you share a screen shot of the subassembly if possible.
Rail Community
