we've been asked to develop a pond on a piece of property. We know the volume we want in the pond, but would like to preview different scenarios of depth and layout. Anybody direct me on how to handle these "what-ifs" How would you go about doing this? THanks
The entire bottom will be completely flat? Will the sides be sloped evenly around the entire perimeter?
Is there a tolerance (such as plus or minus XX cf)?
Don Ireland
Engineering Design Technician
@MKH-VB wrote:
3:1 ss.
I can model the bottom of the pond. I was just wondering how I could move 1 side of the pond back and forth and check the volume in it.
For checking the volume, I would draw a rectangle that's larger than the entire pond. Place it at the water elevation and make a surface with this rectange as the only breakline. That surface represents the "water surface". Then once you have the "Pond Surface", you can create a "Volume Surface" which compares the two , The difference between them is how much water the pond will hold.
Don Ireland
If this was a small pond and I needed to present these to a client or someone else I would make 3 base feature lines on different sites and layers. Use more Flines, gradings or corridors on each one to get each design. Label it all up and xref it into a new sheet file with the base maps. THe layers should make it easy to set up each viewport and save layer states for each design scenario.
Once the client or whoever picked a design I would open that file and create a data shortcut to the chosen basin OR Insert that file into a new file, delete the unwanted basins and continue to design.
If it was a large basin I might do each design in a separate file.
John Mayo
Here's a quick example (done using C3D 2012).
Don Ireland
