Civil 3D Forum
where is Subassembly Composer 2015?
3 REPLIES 3
joantopo
3350 Views, 3 Replies
Hi.
Last year, when I installed Civil 3D 2014, during the installation I activated a checkbox to install Subassembly Composer 2014 too.
Now, I have installed Civil 3D 2015 but I haven´t seen that option.
I have not SAC 2015 in Autodesk folder.
How can I install it then?
And other cuestion: is it possible to do a customized installation in Civil 3D 2015?
Thanks.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
3 REPLIES 3
joantopo
in reply to: joantopo
http://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticle...
neilyj666
I'd ticked that box when I installed and just checked and SAC 2015 is not installed.
Went to reinstall off the USB media and the Install option is greyed out - one for Support I think
EDIT: Just checked in Windows Control Panel and it apparently IS installed; now just got to find it....2014-06-06 19_48_31-Control Panel_All Control Panel Items_Programs and Features.jpg
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
neilyj666
in reply to: neilyj666
Panic over found it - C:\Program Files (x86)\Autodesk\Subassembly Composer 2015\SubassemblyComposer.exe
Rail Community
