Civil 3D Forum
when opening a drawing contained many gradings, Re-Grade all. So much Time open
3 REPLIES 3
242 Views, 3 Replies
hi Everyone,
Result = So much Time for openning a drawing
using the datashortcuts : cannot right grading with corridor between other areas.
       if u use the corridor dayligt , area grading and corridor grading is created seperately
      if u use the dinamic feature lines and grading with that way , area grading and corridor grading Right is created RIGHT WAY.
                    But when re-open the drawing, drawing RE-GRADE all finished grading and waiting toooooo much time
THAT S A BIG PROBLEM FOR BIG AREAS OR LONG WAYS
how to solve the RE-GRADING problem on when opening Drawings
3 REPLIES 3
BrianHailey
The problem is you are targeting a surface with your grading that is being data referenced into your drawing. When you open the drawing, the surface synchronizes with the original surface. When the surface synchronized it basically rebuilds and the grading recomputes. To get around this, create a new blank surface in your grading drawing and paste in the data referenced surface and do NOT turn on Rebuild Automatic. Now use this new surface as the target for the grading. The primary drawback to this is if the original surface changes, you'll need to manually rebuild the grading target surface.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
neilyj666
This is something that I find quite irritating as well; hopefully this tip will get around it...Smiley Happy
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
thank you very very  much for your help
in my opinion that tip useful for everyone
Rail Community
