Sounds good.
Sure, if you can't get it, post it - I'll look at it when I get a chance.
sm
Scott McEachron
DC CADD, Dallas - Fort Worth
http://c3dpavingtheway.blogspot.com/
wrote in message news:5369761@discussion.autodesk.com...
nice looking layout, i dont doubt the your solution at all. i can see it
works. yes, i am using bpoly to define the area for subdividing. there is
one spot that bpoly would not work so i overlined it with a poly line, which
is the same as poly line. it worked on your example, i followed it to a
tee. let me try once more. i will attach it if it has problems this time
and maybe you can explain what i am doing incorrect. thank you in advance
for your expertise.
