in order to avoid opening each layout and update the fields or the same text written in Title Block
- is there a way to update automatically the fields (date for example) in all the layouts with a single command.
- is there a way to update the same text in all the layouts (for example changing the adress or the name of the project written in the title block - like in word with search and replace function )
MHB
Rick Jackson
Survey CAD Technician VI
neilyj (No connection with Autodesk other than using the products in the real world)
I agree with Neilyj but I would warn that IME the SSM can really slow down your productivity depending on the server. I believe using a title block reference would be a better solution personally.
Do you want the date to reflect the current date, always - or only when you choose to update it?
See also: http://cadpanacea.com/node/11
Well, that's the most valuable information that's been share with me this week!
That's not what the help says.
0 | Do not automatically refresh the status data in a sheet set |
1 | Refresh the status data when the sheet set is loaded or updated |
2 | Refresh the status data when the sheet set is loaded or updated, or at a time interval set by SSMPOLLTIME |
(In other words if set to 2 it will ping every 60 seconds.)
Mark Green
Working on Civil 3D in Canada
