I am unable to delete points from my survey database. What could be preventing me from performing this task?
Hi Willy,
You may want to refer to the section "To Delete Survey Points" from the Help doc: http://docs.autodesk.com/MAP/2010/ENU/AutoCAD%20Map%203D%202010%20User%20Documentation/HTML%20Help/i...
You may also refer to the following thread: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Removing-points-from-the-survey-database/td-p...
