Civil 3D Forum
unable to delete point group
3 REPLIES 3
anniesball72
6625 Views, 3 Replies
I am using C3D 2011 x64 on a Win7 64 bit macine.
I am unable to delete two point groups from my Tool Space. Both point groups are empty with no points configured for use with them. How do I get rid of them? When the point groups are selected nothing shows up in the lower window. One of the point groups has the ! mark on it.
Any help would be appreciated.
3 REPLIES 3
sjg
in reply to: anniesball72
Not sure if this is it, but did you use the point group do generate a surface?
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
The exclamation point you are seeing means that the point group needs to be updated.  Even if there are no points in the point group, it still has to be updated before you can delete it.  Right-click on the point group, select Update, right-click on it again, then Delete.  That should do it.  Keep in mind, the All Points point group CANNOT be deleted or edited.
Todd Rogers
Use lock, unlock, delete.
Rail Community
