Survey database is open for edit, drawing displays survey points and figures from imported survey data files. When I try to use _AeccCreatePointManual, after selecting a location, entering a description and elevation, no point is created. The command appears to complete and gives no error but no point shows up in the drawing or survey database. Default layer is <use current>.
Points>Create Points>
You'll get a dialog box and click on Point Identity.
Have you checked your POINT STYLE/LABEL STYLE?
David
