Civil 3D Forum
trouble with subassembly "urbanCurbGutterGeneral".
2 REPLIES 2
joantopo
3050 Views, 2 Replies
 I have used the subassembly "urbanCurbGutterGeneral" with the value "extension subbase" = 0.30m.
However, in the section view, with the "datum" surface  displayed (red line), this surface doesn ´t finish in the edge of extension subbase:
zoom:
What´s the matter?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
2 REPLIES 2
sboon
in reply to: joantopo
The underside of the Curb SubBase and the Urban sidewalk both use the Datum code.  If you apply that code to your surface then the software doesn't know what to do where the two links overlap.  In the corridor surfaces tab you can specify the overhang correction option which will help.
In this case if you set the overhang correction to bottom you're probably going to get a surface that runs diagonally from the outside corner of the subbase extension to the ouside corner of the sidewalk.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
joantopo
in reply to: sboon
Yes,  you´re right.
With Overhang correction= bottom :
Thank you.
Rail Community
