AutoCAD Civil 3D General
Valued Mentor
joantopo
Message 1 of 3 (261 Views)
trouble with subassembly "urbanCurbGutterGeneral".
261 Views, 2 Replies
08-24-2013 01:22 PM
 I have used the subassembly "urbanCurbGutterGeneral" with the value "extension subbase" = 0.30m.
However, in the section view, with the "datum" surface  displayed (red line), this surface doesn ´t finish in the edge of extension subbase:
zoom:
What´s the matter?
Thank you.
Autocad Civil 3D 2014 +SP1
Quad Core Intel i7 3770-cpu 3.40Ghz.
ssd samsung 840 pro 512gb+ssd samsung 840 pro 256 gb+1tb hdd
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
sboon
Message 2 of 3 (233 Views)
Re: trouble with subassembly "urbanCurbGutterGeneral".
08-24-2013 05:07 PM in reply to: joantopo
The underside of the Curb SubBase and the Urban sidewalk both use the Datum code.  If you apply that code to your surface then the software doesn't know what to do where the two links overlap.  In the corridor surfaces tab you can specify the overhang correction option which will help.
In this case if you set the overhang correction to bottom you're probably going to get a surface that runs diagonally from the outside corner of the subbase extension to the ouside corner of the sidewalk.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Valued Mentor
joantopo
Message 3 of 3 (218 Views)
08-25-2013 07:48 AM in reply to: sboon
Yes,  you´re right.
With Overhang correction= bottom :
Thank you.
32gb RAM 1600 Mhz.
nVidia Quadro 2000.
Win 7 Pro 64bit
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
