AutoCAD Civil 3D General
Joe-Bouza
Message 1 of 9 (184 Views)
trouble exporting to plain autocad
184 Views, 8 Replies
06-28-2012 02:46 PM
If I audit or recover this file I get no errors, but if I try to export or batch and explode aec object I get error...try recover and no file gets created. Any suggestions?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
tcorey
Message 2 of 9 (176 Views)
Re: trouble exporting to plain autocad
06-28-2012 04:36 PM in reply to: Joe-Bouza
Hi Joe,
Can you Exportotautocadr12dxf? I usually go to this format as a standby when nothing else works. Maybe it will work for you.
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Joe-Bouza
Message 3 of 9 (164 Views)
06-28-2012 07:03 PM in reply to: tcorey
Hi Tim
Thanks, that should work, I'll give it a go in the morning
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Active Contributor
Message 4 of 9 (156 Views)
06-28-2012 10:41 PM in reply to: Joe-Bouza
This happens to me too.  I do not want a DXF file, I would like to export to AutoCAD like it's supposed to.
Carl M. Fiorica, P.E., LEED A.P.
Burkett and Wong Engineers
3434 4th Ave
San Diego, CA 92103
neilyj
Message 5 of 9 (150 Views)
06-29-2012 02:31 AM in reply to: Joe-Bouza
I've had issues when XREF's are in the drawing.
I do a SAVEAS, BIND the Xrefs and EXPORT then CLOSE the drawing without Saving - seems to work
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Joe-Bouza
Message 6 of 9 (142 Views)
06-29-2012 06:19 AM in reply to: neilyj
I'm still having trouble, I don't have xrefs but do have datalinks that cannot be bound, detached  or unloaded? I thimks I PDF is my only option
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
neilyj
Message 7 of 9 (131 Views)
06-29-2012 06:51 AM in reply to: Joe-Bouza
What about DWF ??
If you are wanting to use as an underlay, I have had much better results with a DWF rather than a pdf
neilyj
jmayo
Message 8 of 9 (127 Views)
06-29-2012 07:36 AM in reply to: Joe-Bouza
I agree with that Neil. Popping a pdf into a dwg is the best way I know to make AutoCAD slow to a crawl.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Joe-Bouza
Message 9 of 9 (122 Views)
06-29-2012 08:48 AM in reply to: jmayo
Dwf, PDF, it make no diff to me I'm sending the drawing out.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
