Civil 3D Forum
trouble exporting to plain autocad
8 REPLIES 8
Message 1 of 9
Joe-Bouza
444 Views, 8 Replies
If I audit or recover this file I get no errors, but if I try to export or batch and explode aec object I get error...try recover and no file gets created. Any suggestions?
Your Name
8 REPLIES 8
Message 2 of 9
tcorey
in reply to: Joe-Bouza
Hi Joe,
Can you Exportotautocadr12dxf? I usually go to this format as a standby when nothing else works. Maybe it will work for you.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
Joe-Bouza
in reply to: tcorey
Hi Tim
Thanks, that should work, I'll give it a go in the morning
Your Name
Message 4 of 9
cfiorica
This happens to me too.  I do not want a DXF file, I would like to export to AutoCAD like it's supposed to.
Carl M. Fiorica, P.E., LEED A.P.
BWE, Inc
9494 Balboa Ave, Ste 270
San Diego, CA 92123
Message 5 of 9
neilyj666
I've had issues when XREF's are in the drawing.
I do a SAVEAS, BIND the Xrefs and EXPORT then CLOSE the drawing without Saving - seems to work
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 6 of 9
Joe-Bouza
in reply to: neilyj666
I'm still having trouble, I don't have xrefs but do have datalinks that cannot be bound, detached  or unloaded? I thimks I PDF is my only option
Your Name
Message 7 of 9
neilyj666
What about DWF ??
If you are wanting to use as an underlay, I have had much better results with a DWF rather than a pdf
Message 8 of 9
jmayo-EE
I agree with that Neil. Popping a pdf into a dwg is the best way I know to make AutoCAD slow to a crawl.
John Mayo
Message 9 of 9
Joe-Bouza
in reply to: jmayo-EE
Dwf, PDF, it make no diff to me I'm sending the drawing out.
Your Name
Rail Community
