Hello, I am having trouble with the traverse analysis in civil 3d 2011. I have a point file with my traverse points(there were no side shots). I imported the points into a local database and I created a network. I have created a traverse and entered in the data for the traverse. When I go to do an analysis, it says that my first station has unknown coords. Any idea why it would be doing this? I am new to civil 3d and this is the first traverse i have had to adjust. Any help would be appreciated!
Chris
I am at the airport between flights, so my apologies for the short reply.
Post your dataset I will look into it.
Did you import points via points import or through the Survey tool space?
If you are on Subscription you can download the 2011 Subscription Advantage Pack which includes this.
John Mayo
