AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 13 (321 Views)
Accepted Solution
tool palette dock and closed
321 Views, 12 Replies
10-24-2012 10:07 AM
i am getting a message when i click on something from my tool palette saying that it does not display when it is docked and closed. how do i undo this so i can use objects from the tool palette. how do i "unlock" it? see image.
thanks.
*Expert Elite*
AllenJessup
Message 2 of 13 (318 Views)
Re: tool palette dock and closed
10-24-2012 10:13 AM in reply to: MonkeyTrainer
CTRL + F3 should open the toolpallet. Then you can undock it if you want.
Allen
Message 3 of 13 (315 Views)
10-24-2012 10:15 AM in reply to: AllenJessup
unLOCK. it doesnt matter if its DOCKED or not
thanks.
*Expert Elite*
AllenJessup
Message 4 of 13 (313 Views)
10-24-2012 10:20 AM in reply to: AllenJessup
Sorry. Should be CTRL + F1 for the Properties Pallet. Or select an entity, rt click and select properties from the menu.
Allen
Message 5 of 13 (310 Views)
10-24-2012 10:23 AM in reply to: AllenJessup
ok, maybe im not being clear enough. the objects on my tool palette are locked. thats it.
thanks for posting.
*Expert Elite*
AllenJessup
Message 6 of 13 (309 Views)
10-24-2012 10:24 AM in reply to: MonkeyTrainer
After rereading your post and the attached error. I'm thinking that the something you're click on in the toolpalette is a subassembly or other item that has properties editable in the Properties palette. So you need to open your Properties window.
Allen
Message 7 of 13 (307 Views)
10-24-2012 10:26 AM in reply to: AllenJessup
ok, there is nothing editable in the properties box referring to an object being lockable.
*Expert Elite*
AllenJessup
Message 8 of 13 (306 Views)
10-24-2012 10:26 AM in reply to: MonkeyTrainer
Or I'm being dense today. I don't know how to Lock a toolpalette so I can't say how to Unlock it. At this point my best guess is that you need to open your Properties Palette.
Allen
Message 9 of 13 (303 Views)
10-24-2012 10:28 AM in reply to: AllenJessup
do you know how to do that besides CTRL + F1? we changed our script for the f1 key.
*Expert Elite*
AllenJessup
Message 10 of 13 (302 Views)
10-24-2012 10:28 AM in reply to: MonkeyTrainer
We keep crossing our post. So your latest invalidates my latest. From reading the error message that was the best I could come up with.
Allen
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
