AutoCAD Civil 3D General
Valued Contributor
Message 1 of 6 (191 Views)
tin lines
191 Views, 5 Replies
01-29-2013 05:14 AM
I created a surface with a boundary. At a couple locations near the boundary line, there are areas where there are no tin lines. I keep trying to add lines in order to fill in these areas but the software will not allow me to draw the lines. Would anyone be able to think of any reasons why this might be?
I tried moving the boundary outward, and at one of the locations the TIN lines came in after rebuilding the surface. The same cannot be said for the other locations, however.
Any ideas would be appreciated.
Thanks very much
Wil
*Expert Elite*
AllenJessup
Message 2 of 6 (188 Views)
Re: tin lines
01-29-2013 05:25 AM in reply to: DrWileFTracer
I believe you need to use non-destructive breaklines when creating the boundary.
Non-Destructive Breakline
Specifies whether or not to create boundaries with non-destructive breaklines. This clips the triangle edges exactly where they cross the boundary.
*Pro
Message 3 of 6 (186 Views)
Re: tin lines
01-29-2013 05:33 AM in reply to: DrWileFTracer
can  you post the surface, or at least a small portion of the surface where the problem exists?
someone may be able to find a solution.
I've had similar issues and always seemed to be able to get the tin lines to show eventually.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Mentor
Message 4 of 6 (178 Views)
Re: tin lines
01-29-2013 05:50 AM in reply to: DrWileFTracer
Sometimes it is easier to force the tin lines by adding a surface point instead of adding lines.
Distinguished Contributor
Message 5 of 6 (145 Views)
Re: tin lines
01-29-2013 04:09 PM in reply to: DrWileFTracer
You are probably exceeding the maximum triangle lenght.
Surveyor Lee
*Expert Elite*
jmayo
Message 6 of 6 (122 Views)
Re: tin lines
01-30-2013 06:38 AM in reply to: DrWileFTracer
One of the first things to check when you have boundary issues is to make sure that they are modeled in the correct order. A single outer boudary would typically be the last operation on a surface. If you are unsure about the operation order of your boundary, open the surface's properties dialog. Go to the definition tab and look for your boundary operation in the operations list. If it is not last select it and use the arrow buttons to the left to move it down. Rebuild and see if the boundary is processed correctly.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
