Civil 3D Forum
text style changing
4 REPLIES 4
601 Views, 4 Replies
text style changing
I am using Civil 3D 2012 and seem to have a reoccurring problem with the text styles changing. At the start of the day, I will open my drawing and find that my text style has changed and I am not sure what is causing this. I check my text styles and none of my settings has change nor has the text style. Nothing seems to fix the problem other than running a repair of the system. I was wondering if anyone has experienced this problem before and what his or her solution might have been.
Tim Strickland
4 REPLIES 4
jmayo-EE
I have seen this issue a number of times and I just edit the label style or use importstylesanssettings to get the text style back. I think the text style reverts to Standard when data is moved between files but have no real explanation since I know that the text style replaced always exists in every file.
John Mayo
Joe-Bouza
Is the style changing or the font the style uses?
Joe Bouza
in reply to: Joe-Bouza
Visually it is the font the style that is changing, but when I go and check my font for the particular style within my style manager it has not changed. It is the weirdest thing I have seen. If it was just a visual problem I could deal with it but when I publish it reflects the changes.
Tim Strickland
Joe-Bouza
And you check your font path in option dialog? I see this from time to time and the default font takes over if the prescribed font is not found
Joe Bouza
Rail Community
