Hi guys, I was wondering if anyone knew how to import all the settings and styles from a template into an exsisting drawing. Without inserting into the template or individually dragging from the settings tab.
Brandon Hayter
Solved by michael.robertson. Go to Solution.
If you are using C3D 2011 I believe AECCIMPORTSTYLESANDSETTINGS will do what you are wanting (be aware that if there are any style names in the file you are importing to that match the style name you are importing form that the existing style will be changed to match the import.
Here's a blog post on the subject that also covers bringing styles and commands over in holder version: http://civil3dguru.blogspot.com/2010/06/undocumented-aec-style-commands-civil.html
