AutoCAD Civil 3D General
Active Member
Message 21 of 29 (502 Views)
Re: symbols attached to points...
03-15-2012 08:34 AM in reply to: JeffPaulsen
See attached file. This is a initial process of field work. Civil 3D 2012.
Distinguished Mentor
Message 22 of 29 (501 Views)
03-15-2012 08:40 AM in reply to: jsauler
All of your points layers are set to no plot. Change the layer setting so they do plot.
Turn off layer points. The labels will turn off and the symbols will stay on.
Jeff Paulsen
Civil 3D 2012 SP3 | Win 7 64-bit SP1
Xeon E5-1620 @ 3.60GHz, 16GB Ram | NVidia Quadro 600
Active Member
Message 23 of 29 (499 Views)
03-15-2012 08:45 AM in reply to: JeffPaulsen
So what is the point of the description keys and the layer information in there?
Active Member
Message 24 of 29 (497 Views)
03-15-2012 08:51 AM in reply to: JeffPaulsen
I guess I meant to ask what is the point to set the Marker to one layer and the lebel to another if it doesn't recgonize them as seperate entities?
*Expert Elite*
sboon
Message 25 of 29 (494 Views)
03-15-2012 09:05 AM in reply to: jsauler
It does recognize them as separate, but it puts all of the labels on a single layer.  You can use the DescKeys to decide what type of label to attach to each point, or have no label at all for some.  I typically have no label for points that display symbols.
You can also set a layer within the point label style, although that's not my preferred method.  If you do it that way then you can freeze the layer to hide all point labels using that style.
Active Member
Message 26 of 29 (487 Views)
03-15-2012 09:22 AM in reply to: sboon
I am confused on the single layer for the points. If you have a point style created and the marker is designated as its own layer and you the lebel is designated as a seperate layer why will the marker dissapear when i freeze the points layer? Example is a gas meter is set to be on  EX-GAS layer designated under the Marker component type and the Layer is Points-Utilities under the Label component type. If I freeze the Points-Utilities layer the "block" that I have designated to be on the EX-GAS layer dissapears.  Is there a way to set it up to insert a block that is "not" a point marker? And by this I mean say a Tree that the block has attributes so we could apply a name and size, or is this a manual task?  I could be creating a headache but I am just trying to understand where I am goig wrong.
I appreciate yours and Jeff Paulson's help on this.
Message 27 of 29 (484 Views)
03-15-2012 09:25 AM in reply to: jsauler
It reacts just like a block or xref in AutoCAD. An xref can contain any number of layers. Those layers can be turned on and off as desired. The xref is inserted in the drawing on one layer. If that layer is frozen none of the layers within the xref display. I hope this helps.
Jeff Paulsen
*Expert Elite*
sboon
Message 28 of 29 (482 Views)
03-15-2012 09:35 AM in reply to: jsauler
Autodesk assumes that if you freeze an object's layer then you don't want to see it's labels either.  You can do the same thing with an alignment or a surface.  If you have several alignments with station labels in your drawing you can freeze the single layer which all of those labels are on and they all disappear, or you can freeze the layer of one alignment and only those labels with go away.
As far as editing the block attributes after inserting a point - no you unfortunately cannot edit the block.  What you can do however is use the parameter controls in your DescKey to change the size or rotation of the block, and you can customize an individual point label to show field survey comments or other info.  The Autodesk point tutorials have an example where they change the size of a tree symbol to reflect the surveyed diameter, and the label shows the species for each point.
Active Member
Message 29 of 29 (478 Views)
03-15-2012 09:40 AM in reply to: sboon
Thanks to the both of you for the help.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
