im using civil 3d 2010 and i have problem when for survey figure prefix database (see attachment). i can still open my drawing by ignoring the dialog box but when i check the propector under the survey tab, the figure frefix is empty. i try to create a new one but it says "the figure database does not exist and could not created".
please help me.
thanks.
Is you figure prefix database stored in a network location?
I recall having problems with the figure prefix database at some point, and it involved a corrupt prefix database. Once i deleted that, i was able to create a new prefix database, but until that was gone, I wasn't able to do anything.
If not networked, you could try backing up you prefix database/s and then move them to a different location and see what happens. If you have more than one, move them back one at a time until you find the dud one.
I tent to agree with Andrew. I think you have corrupted file there. I'd see if you can delete that Figure Prefix DB file and copy it from somewhere else. Then see if it works better.
it works! i have a back up copy before of my survey folder, i overwrite the whole folder of survey containg figure prefix database............. great..
thanks to both of you guys..
