Civil 3D Forum
surface spot elevations having diffent color for different ranges.
3 REPLIES 3
Cashman_Dredging1
382 Views, 3 Replies
I'm trying to create a cut and fill map and was wondering if anyone was succefull at labeling a surface with spot grades that have different colors according to what range they belong to. For instance, If I have a cut and fill surface with 10ft cut (max) and 10ft fill(max), Then from elev 10 to 5 the spot grades would be light green, 5 to 0 the spot grades would be dark green, 0 to -5 light red, -5 to -10 dark red.
I think this can be done using expression, but I not sure what the formula has to be.
Any other other ideas on how accomplish this are welcome.
3 REPLIES 3
Check out Seth Hall's remedy for this...
http://beingcivil.typepad.com/my_weblog/2009/02/color-cutfill-surface-labels.html
Todd Rogers
~Opie
in reply to: Cashman_Dredging1
With your variable ranges, I do not think this is possible. An expression does not provide a return value that is usable for specifying specific colors. Also, the color picker dialog does not allow for expression variable names.
Can only do cut and fill i.e positive or negative values only
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
