Civil 3D Forum
surface size problems
3 REPLIES 3
smckee1
285 Views, 3 Replies
thank you all for your previous help
new question is what can be done to reduce the file size for a contour surface?
if the contours lines are created in database and imported will it reduce the amount of data regenerated with each command?
3 REPLIES 3
Jay_B
in reply to: smckee1
What does the above mean, what's the process / workflow here?
If you've brought in contours from some other source and there are way too many vertices along these contours they
can easily be cleaned up or weeded using the MAPCLEAN command.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
smckee1
in reply to: Jay_B
thanks a bunch
I am maxing my machine out with simple move command and was trying to speed things up.
the surface was created in civil 3d (same machine and software) it is 250 mb when created. I believe I can change style to no view but I do need it to be visible eventually.
Thank you
Skip Mckee
(C) 1-509-948-0492
(O) 1-864-467-0811 ext.115
DESIGN GROUP
NORTH WIND INC.
A CIRI COMPANY
Skip McKee
Graphics Design
North Wind Inc
A CIRI Company
Phone: (864) 467-0811
Email: amckee@northwindgrp.com
Please consider the environment before printing.
This e-mail and any files transmitted with it may be business sensitive and are intended solely for the use of the individual to whom they are addressed. If you are not the intended recipient or the person responsible for delivering the e-mail to the intended recipient, be advised that you have received this e-mail in error and that any use, dissemination, forwarding, printing or copying of this e-mail is strictly prohibited. If you have received this e-mail in error, please immediately advise the sender by reply e-mail and delete the e-mail. We appreciate your cooperation.
ericcollins6932
You can try simplifying the surface.
  • Click Modify tab Ground Data panel Surface.
  • Click Surface tab Modify panel Edit Surface drop-down Simplify Surface.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Rail Community
