I have some problem. I hage alignement of wall or embankment. I have existing ground inlucding this corridor river. I have also CSV file with points (x,y,z). On my sketch there is drawn. Points present FDL (flow defence level) maximum level of river in case of huge rain or other things. These are almost aligned. I need to transform it (project) into alignment. I have to create profile of EG, FDL (based on this point) and then create new profile of heght of wall or bank. What is the best solution for projecting this points. I tried with grading (distance and grade0%) I traied then with offsettinh this feature line based on points and used it as breaklines. Created surface had holes. If thre is better way? This situation is simillr to my. Even real is worst becuase alignemnt is perpendicular in same places to river.
Mark Green
Working on Civil 3D in Canada
Mark Green
