Civil 3D Forum
surface data shortcut not update
8 REPLIES 8
Message 1 of 9
annw2
883 Views, 8 Replies
either I found a bug or I am doing something wrong.
Main drawing with corridor & corridor surface.
Create data shortcut to second volume drawing - EG & corridor surface. Create volume surface between 2 & get volume.
Revise corridor surface in first file.
Open volume file - Syncronize and rebuild volume TIN - No change to cut fill volumes.
Open first file - see no evidence of data shortcuts under general edit data shortcuts.
Explorer - no evidence that the xml file was updated i.e. old date.
2008 sp1
Can anyone tell me what I am doing wrong? Am I missing a step here?
Ann Wingert, P.E.
8 REPLIES 8
Message 2 of 9
in reply to: annw2
I haven't experienced any problems. There would not be an updated in the
XML (I don't think), as the chance was in the DWG containing the surfaces.
The XML would not have to change in that scenario: It still points to the
same surface in the same drawing.
Have you rebuilt the volume surface?
wrote in message news:5714485@discussion.autodesk.com...
volumes.
shortcuts.
2008 sp1
Message 3 of 9
annw2
in reply to: annw2
Several times
Ann Wingert, P.E.
Message 4 of 9
annw2
in reply to: annw2
Found volume function under surface utility menu.
Ann Wingert, P.E.
Message 5 of 9
mjfarrell
in reply to: annw2
You might want to get you volumes for the corridor, under sections>>Compute Materials
Message 6 of 9
in reply to: annw2
I have just encountered a similar problem. Edited surface (built from corridor) in corridor dwg. Opened interesection dwg (which uses the corridor surface). Link broken.
Seems to be how a surface from corridors function. Too much "messing" with the corridor causes problems on the shortcuts.
Why is there not a field in the surface properties of a shortcut reference that allows you to change the location or re-link to the reference?? Once the surface is imported from the .xml file, you are stuck with that embedded handle in your dwg!
Clem
c3d 2008 sp1
Message 7 of 9
in reply to: annw2
I'll second this.
This is, in my opinion, a potentially HUGE issue that seems to be easily
corrected.
Vault is not a realistic solution for everyone..........period.
wrote in message news:5716201@discussion.autodesk.com...
handle in your dwg!
Message 8 of 9
in reply to: annw2
ahmen on the vault not being for everyone! Been there, tried it quite extensively. A few webcasts ago, there was a poll on the use of vault. Very FEW are actually using vault.
Sorry Wedding, I probably will still come to your AU class!
Clem
Message 9 of 9
annw2
in reply to: annw2
I would if it were just a simple road corridor. This a shopping center with the corridor used only for the spine. The rest is grading features for buildings & parking lots.
I am also having odd results with the surface volume calc as well. I ran it, then made changes to corridor, came back into the function and the volume calc was gone. I thought it was supposed to stay and update? I just re created for that plot.
I am trying to learn one thing at a time. Since it is just me, my self, and I, I was starting with shortcuts. I am leaving vault until later.
Ann Wingert, P.E.
Rail Community
