I am using a LINKOFFSETANDELEVATION subassebly
but I'm having a problem getting the right result
as it links to whatever side it finds the target object nearest
(the target is a polyline that goes around the alignment)
Is there a way to force the link's direction strictly to a specific side, even if the distance to the target is smaller at the opposite side?
thank you
Can you break the target polyline into 2 parts so you'd have a TargetLeft and a TargetRight?
Don Ireland
Engineering Design Technician
Does this image resemble what you need (where the white line is the alignment and the green line is the target)?
Don Ireland
not exactly,
it's the top of a landfill (green = alignment) linking to the toe feature line (yellow)
what you see is what I finally managed ending up with a lane subassembly instead
where you have the option of choosing a side.
there are other ways (not grading though, or it's me not getting along with so good)
but I really need to show these slope patterns, so I had to use a corridor
thnak you for your time
