Civil 3D 2012 in realistic view
occasionally when I orbit the model it 'sticks' in the orbit function - escape and enter do not end the function, and the command line is blank. Usually I have to end the program and restart.
Solved by granite07. Go to Solution.
it 'unstuck' - I right clicked, selected options and then cancled options, orbit function then ended.
got stuck in orbit again - the right click for options must be done in the command field
also, stuck in orbit usually happens in realistic view
Now tha NASA has been closed do you think that will happen more often?
Your Name
Your Name
No.... no, I don't think so.
Anyways, this fix does not work in C3D 2013 - I tried selecting options in the command line and selecting options does not open the dialog box.
If anyone finds a fix, please let me know.
Wait, it does work - options just opened five times after moving the orbit a bit.
