AutoCAD Civil 3D General
Valued Mentor
Message 1 of 3 (223 Views)
stream restoration design question
223 Views, 2 Replies
06-24-2013 08:14 AM
i am looking to get some advice on how to do a stream restoration design with corridor modeling. for the low flow channel pool, i will have alternate riffle and pool sections. my understanding is riffle for X feet, then pool for Y feet, then repeat, per the riffle to pool spacing requirements.
my question is regarding the left pool and right pool sections. please see attached images. for left pool, width A > width B and vice versa. A+B is the same for both left and right pools. left pool assembly has to be applied when the centerline alignment is curving outward to the left side, right pool when curving outward to the right side.
is there a way to specify in corridor modeling when an assembly is to be applied based on the direction of the centerline alignment curves? i am not hung up on doing this with corridors, so if there is not a way, I would love to hear other people's thoughts on how to best approach this grading work.
Civil 3D 2013 SP1, Win 7-64 bit
12GB RAM
*Expert Elite*
Joe-Bouza
Message 2 of 3 (177 Views)
Re: stream restoration design question
06-24-2013 10:20 AM in reply to: engineer4life1979
Im not very stron on conditional assemblies but I understand they can target a polyline. You can place a target pline where you do or dont want the pool assembly
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Employee
Message 3 of 3 (166 Views)
06-24-2013 10:53 AM in reply to: Joe-Bouza
Conditional SA are one way to do this, another would be to use offset alignments and apply a manual widing to the outside of the curves. Then use these new alignments to tie the bottom of the stream/pool to.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
