I'm having an interesting problem when converting autocad points to civil 3d points, the sequence doesn't make any sense. I can't share my model but I can show you my settings in the "Create point toolbox".
"Edited with a print screen caption"
In what way do they not make sense? Are they offset, random or something else? Is it possible that points in this range already exist?
Allen
Allen Jessup
CAD Manager - Designer
I want my numbers to be numbered 1.2.3....1xx, next series: 201, 203...3xx etc. The first selection has the 1xx so points and the second has 201-3xx points. But they won't behave.
Point handling and Point renumbering occurs if there is a collision.
To work around "needing" a collision, you'll need to know the following:
1. The additional imports of points will not crash into previous "point sets" like the 1xx series, or the 2xx series
2. You'll need to know the first point number of the next set you wish to import
3. Set the create points settings as follows:
Point number offset = the calculated difference from your first point number and 2xx series
If Point numbers are supplied = Add an Offset
This should allow you to renumber the Raw points from sub sequent imports into the 1xx, 2xx, and so on series in your drawing.
Thanks for you reply, I will use your techniques in my upcoming project where I have proper starting files.
The project I'm working on right now involves autocad points that are already in a drawing, I converted these points using the convert autocad points command using the settings in my attached files. I get my numbers from 1-1xx alright, but the order does not make any sense. My first point is showing as 91, followed by 5, 92, 93, 94, 4, 95, 96, 97, 98, 3 etc.
Btw, I noticed that I wrote number sequence in my subject, number order would have been a better choice, I think.
Are you talking about the position of the points on the screen, i.e.. point 98 is furthest to the NW and point 3 is next to it. Or are you referring to the order in the point list. If it's the order in the point list. Try resorting the list by point #.
Allen
Allen Jessup
I did a little experimentation and it looks like the point numbers will be assigned in the order of the creation of the AutoCAD points. So if the points appear scattered across the screen. It's because they were created in that order.
Allen
Allen Jessup
Yes, the points displayed on screen 😃
I see, thank you very much!
