Show only
Search instead for
Pipe inverts of structures in profile view do not show - i've already checked if the pipe is referenced to the correct alignment. Any idea what I'm missing to set? Thanks.
Not sure if your referring to the label or the structure display of pipes. For display of pipes in structure go to your structure style properties, under the profile pulldown, check to see if structure pipe outline in on. For label make sure you have "text for each" component in your label style.
Steve Goessling Land Consultants Civil3D 2015 Windows 7, 64 bit Intel i7 2600 @ 3.40Ghz 16 GB RAM Nvidia Quadro 600
